HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
A Theoretical Framework for IT-Enabled and IT-Enforced Corporate Governance Compliance Utilizing BPMSs
Abstract : Corporate governance has been severely condemned, as a result of company failures around the world. Regulatory and legislative measure have been introduced in response to these failures. However, arguments by sceptics advocate that it is time consuming and costly to comply these legislative measures that cause overregulation. These measures further do not always add value to business initiatives and adherence to these measures cannot be enforced or guaranteed. This paper argues for the use of business process management systems (BPMSs) to improve corporate governance. The “dynamics capabilities theory model of IT-enabled organisational performance” [1] is applied in this study as theoretical underpinning. A theoretical framework is proposed for IT-enabled and IT-enforced corporate governance compliance using a BPMS, after collecting data from seven BPMS user companies and a BPMS vendor company in South Africa.
Complete list of metadata
https://hal.inria.fr/hal-03222866
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, May 10, 2021 - 3:02:12 PM
Last modification on : Monday, May 10, 2021 - 3:08:55 PM
Long-term archiving on: : Wednesday, August 11, 2021 - 7:47:50 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2023-01-01
Please log in to resquest access to the document
Identifiers
Citation
Hendrik Pretorius, Alta Merwe. A Theoretical Framework for IT-Enabled and IT-Enforced Corporate Governance Compliance Utilizing BPMSs. 19th Conference on e-Business, e-Services and e-Society (I3E), Apr 2020, Skukuza, South Africa. pp.301-312, ⟨10.1007/978-3-030-44999-5_25⟩. ⟨hal-03222866⟩
Share
Metrics
Record views
10
