Ghost lineages highly influence the interpretation of introgression tests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systematic Biology Année : 2022
Most species are extinct; those that are not are often unknown. Sequenced and sampled species are often a minority of known ones. Past evolutionary events involving horizontal gene flow, such as horizontal gene transfer, hybridization, introgression and admixture, are therefore likely to involve “ghosts”, i.e. extinct, unknown or unsampled lineages. The existence of these ghost lineages is widely acknowledged, but their possible impact on the detection of gene flow and on the identification of the species involved is largely overlooked. It is generally considered as a possible source of error that, with reasonable approximation, can be ignored. We explore the possible influence of absent species on an evolutionary study by quantifying the effect of ghost lineages on introgression as detected by the popular D-statistic method. We show from simulated data that under certain frequently encountered conditions, the donors and recipients of horizontal gene flow can be wrongly identified if ghost lineages are not taken into account. In particular, having a distant outgroup, which is usually recommended, leads to an increase in the error probability and to false interpretations in most cases. We conclude that introgression from ghost lineages should be systematically considered as an alternative possible, even probable, scenario.
syac011 (9).pdf (755.96 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03455377 , version 1 (10-05-2021)
hal-03455377 , version 2 (08-11-2022)
Théo Tricou, Eric Tannier, Damien M. de Vienne. Ghost lineages highly influence the interpretation of introgression tests. Systematic Biology, 2022, 71 (5), pp.1147-1158. ⟨10.1093/sysbio/syac011⟩. ⟨hal-03455377v2⟩
192 Consultations
40 Téléchargements
