PUMAH : Pan-tilt Ultrasound Mid-Air Haptics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Focused ultrasound mid-air haptic interfaces are ideal for providing tactile feedback in Virtual Reality (VR), as they do not require the user to be tethered to, hold, or wear any device. Using an array of ultrasound emitters, they generate focused points of oscillating high pressure in mid-air, eliciting vibrotactile sensations when encountering a user's skin. These arrays feature a large vertical workspace, but are not capable of displaying stimuli far beyond their horizontal limits, severely limiting their workspace in the lateral dimensions. This demo presents the PUMAH, a low-cost 2 degrees-of-freedom robotic system rotating a focused ultrasound array around the pan and tilt axes, enabling multi-directional tactile feedback and increasing the array's workspace volume more than 14-fold.
Howard_PUMAH_WHC21.pdf (367.91 Ko) Télécharger le fichier
Howard_PUMAH_WHC21.mp4 (19.37 Mo) Télécharger le fichier
hal-03232060 , version 1 (21-05-2021)
  • HAL Id : hal-03232060 , version 1
Thomas Howard, Guillaume Gicquel, Maud Marchal, Anatole Lécuyer, Claudio Pacchierotti. PUMAH : Pan-tilt Ultrasound Mid-Air Haptics. WHC 2021 - IEEE World Haptics Conference, Jul 2021, Montréal / Virtual, Canada. pp.1. ⟨hal-03232060⟩
105 Consultations
97 Téléchargements
