HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Estimation of the tail-index and extreme quantiles from a mixture of heavy-tailed distributions
Abstract : The estimation of extreme quantiles requires adapted methods to extrapolate beyond the largest observation of the sample. Extreme-value theory provides a mathematical framework to tackle this problem together with statistical procedures based on the estimation of the so-called tail-index describing the distribution tail. We focus on heavy-tailed distributions and consider the case where the shape of the distribution tail depends on unknown auxiliary variables. As a consequence, one has to deal with observations from a mixture of heavytailed distributions, and it is shown that, in such a situation, usual extreme-value estimators suffer from a strong bias. We propose several methods to mitigate this bias. Their asymptotic properties are established and their finite sample performance is illustrated both on simulated and real financial data This is joint work with Emmanuel Gobet.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03235031
Contributor : Stephane Girard Connect in order to contact the contributor
Submitted on : Tuesday, May 25, 2021 - 3:58:08 PM
Last modification on : Monday, February 21, 2022 - 8:08:02 AM
Long-term archiving on: : Thursday, August 26, 2021 - 8:23:23 PM
Identifiers
  • HAL Id : hal-03235031, version 1
Collections
Citation
Stéphane Girard, Emmanuel Gobet. Estimation of the tail-index and extreme quantiles from a mixture of heavy-tailed distributions. RESIM 2021 - 13th International Workshop on Rare-Event Simulation, May 2021, Paris / Virtual, France. pp.1. ⟨hal-03235031⟩
Share
Metrics
Record views
83
Files downloads
77
