HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Koszul-type determinantal formulas for families of mixed multilinear systems
Abstract : Effective computation of resultants is a central problem in elimination theory and polynomial system solving. Commonly, we compute the resultant as a quotient of determinants of matrices and we say that there exists a determinantal formula when we can express it as a determinant of a matrix whose elements are the coefficients of the input polynomials. We study the resultant in the context of mixed multilinear polynomial systems, that is multilinear systems with polynomials having different supports, on which determinantal formulas were not known. We construct determinantal formulas for two kind of multilinear systems related to the Multiparameter Eigenvalue Problem (MEP): first, when the polynomials agree in all but one block of variables; second, when the polynomials are bilinear with different supports, related to a bipartite graph. We use the Weyman complex to construct Koszul-type determinantal formulas that generalize Sylvester-type formulas. We can use the matrices associated to these formulas to solve square systems without computing the resultant. The combination of the resultant matrices with the eigenvalue and eigenvector criterion for polynomial systems leads to a new approach for solving MEP.
Complete list of metadata
https://hal.inria.fr/hal-03236344
Contributor : Matías Bender Connect in order to contact the contributor
Submitted on : Wednesday, May 26, 2021 - 11:13:05 AM
Last modification on : Thursday, April 7, 2022 - 1:58:26 PM
Long-term archiving on: : Friday, August 27, 2021 - 6:55:16 PM
2bilinear.pdf
Identifiers
Citation
Matías Bender, Jean-Charles Faugère, Angelos Mantzaflaris, Elias Tsigaridas. Koszul-type determinantal formulas for families of mixed multilinear systems. SIAM Journal on Applied Algebra and Geometry, Society for Industrial and Applied Mathematics 2021, 5 (4), pp.589-619. ⟨10.1137/20M1332190⟩. ⟨hal-03236344⟩
Share
Metrics
Record views
80
Files downloads
109
