Deep Active Learning from Multispectral Data Through Cross-Modality Prediction Inconsistency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Data from multiple sensors provide independent and complementary information, which may improve the robustness and reliability of scene analysis applications. While there exist many large-scale labelled benchmarks acquired by a single sensor, collecting labelled multi-sensor data is more expensive and time-consuming. In this work, we explore the construction of an accurate multispectral (here, visible & thermal cameras) scene analysis system with minimal annotation efforts via an active learning strategy based on the cross-modality prediction inconsistency. Experiments on multiple multispectral datasets and vision tasks demonstrate the effectiveness of our method. In particular, with only 10% of labelled data on KAIST multispectral pedestrian detection dataset, we obtain comparable performance as other fully supervised State-of-the-Art methods.
icip2021.pdf (5.92 Mo) Télécharger le fichier
hal-03236409 , version 1 (26-05-2021)
  • HAL Id : hal-03236409 , version 1
Heng Zhang, Elisa Fromont, Sébastien Lefevre, Bruno Avignon. Deep Active Learning from Multispectral Data Through Cross-Modality Prediction Inconsistency. ICIP 2021 - 28th IEEE International Conference on Image Processing, Sep 2021, Anchorage, United States. pp.1-5. ⟨hal-03236409⟩
188 Consultations
194 Téléchargements
