Abstract : For Cyber-physical systems (CPSs), whose task is to test industrial products, to carry out these tests, highly qualified engineers are always needed to design the tests, since the computational part of the tests is programmed in low-level languages. To optimize this process, it is necessary to create an abstraction of current methods so that tests can be created and executed more efficiently. Although this problem has arisen within the CPS, the architecture we propose will be generic enough to solve the problem in any testing system. We intend to do this by automating some of the current processes to minimize human error. In this paper, we present a novel architecture for a testing system that abstracts single low-level programming and coding of tests, based on two main concepts: the use of Keyword Driven Testing (KDT) that will abstract tests to the person responsible for the machine; the creation of a Domain Specific Language (DSL) to help configure and design new tests without requiring the experience of a highly qualified engineer.
https://hal.inria.fr/hal-03239828 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, May 27, 2021 - 4:43:13 PM Last modification on : Thursday, May 27, 2021 - 4:58:34 PM Long-term archiving on: : Saturday, August 28, 2021 - 8:00:42 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2023-01-01
Ricardo Pereira, Miguel Brito, Ricardo Machado. Architecture Based on Keyword Driven Testing with Domain Specific Language for a Testing System. 32th IFIP International Conference on Testing Software and Systems (ICTSS), Dec 2020, Naples, Italy. pp.310-316, ⟨10.1007/978-3-030-64881-7_21⟩. ⟨hal-03239828⟩
