Between group comparison of AUC in clinical trials with censored follow-up: Application to HIV therapeutic vaccines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistical Methods in Medical Research Année : 2021
In clinical trials, longitudinal data are commonly analyzed and compared between groups using a single summary statistic such as area under the outcome versus time curve (AUC). However, incomplete data, arising from censoring due to a limit of detection or missing data, can bias these analyses. In this article, we present a statistical test based on splines-based mixed-model accounting for both the censoring and missingness mechanisms in the AUC estimation. Inferential properties of the proposed method were evaluated and compared to adhoc approaches and to a nonparametric method through a simulation study based on two-armed trial where trajectories and the proportion of missing data were varied. Simulation results highlights that our approach has significant advantages over the other methods. A real working example from two HIV therapeutic vaccine trials is presented to illustrate the applicability of our approach.
Alexandre_SSMR_2021 (AUC comparison MEM).pdf (807.24 Ko) Télécharger le fichier
hal-03241637 , version 1 (28-05-2021)
hal-03241637 , version 2 (15-12-2021)
Marie Alexandre, Mélanie Prague, Rodolphe Thiébaut. Between group comparison of AUC in clinical trials with censored follow-up: Application to HIV therapeutic vaccines. Statistical Methods in Medical Research, 2021, ⟨10.1177/09622802211023963⟩. ⟨hal-03241637v2⟩
111 Consultations
460 Téléchargements
