Learning robotic needle steering from inverse finite element simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tissue motion compensation during robotic needle steering is a challenging research topic. While the deformable non-linear coupling between needle and tissue is captured by simulation-based control strategies, they increase significantly the computational cost of the control. In this work, we rely on machine learning methods to enable autonomous robotic needle steering with very low computation times. We propose to use an Extreme Learning Machine (ELM) to learn an inverse model which accounts for needle-tissue interaction. The ELM trains with synthetic data generated from multiple needle insertions controlled by inverse finite-element simulations. Results indicate the method is able to achieve clinical compatible precision, and it's robust to previously unseen trajectory-shapes and variable tissue elasticity parameters, while using only a third of the computational time demanded for simulation-based methods.
14-PERRUSI-paper.pdf (2.26 Mo) Télécharger le fichier
hal-03241674 , version 1 (28-05-2021)
  • HAL Id : hal-03241674 , version 1
Pedro Henrique Suruagy Perrusi, Anna Cazzaniga, Paul Baksic, Eleonora Tagliabue, Elena de Momi, et al.. Learning robotic needle steering from inverse finite element simulations. ICRA 2021 - Workshop on Representing and Manipulating Deformable Objects, May 2021, Xi’an / Virtual, China. ⟨hal-03241674⟩
232 Consultations
138 Téléchargements
