HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Effective Access Control in Shared-Operator Multi-tenant Data Stream Management Systems
Abstract : The proliferation of stream-based applications has led to the widespread use of Data Stream Management Systems (DSMSs), which can support the real-time requirements of these applications. DSMSs were developed to efficiently execute continuous queries (CQs) over incoming data. Multiple CQs can be optimized together to form a query network by sharing operators across CQs. DSMSs are also required to enforce access controls over operators according to data providers’ policies. In this paper, we propose the first solution to satisfy access control policies at run-time in shared-operator networks in an non-disruptive, efficient manner. Specifically, we propose a new set of low overhead streaming operators, coined as Privacy Switches (PrSs), which are strategically placed in the operator network to dynamically allow or deny the flow of data in certain branches of the network based upon the current state of access control permissions. Our experimental evaluation confirms that our approach introduces low overheads in the shared operator networks while achieving high savings in the overall network performance.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03243646
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, May 31, 2021 - 5:39:54 PM
Last modification on : Wednesday, November 3, 2021 - 8:17:41 AM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2023-01-01
Please log in to resquest access to the document
Identifiers
Citation
Marian Zaki, Adam Lee, Panos Chrysanthis. Effective Access Control in Shared-Operator Multi-tenant Data Stream Management Systems. 34th IFIP Annual Conference on Data and Applications Security and Privacy (DBSec), Jun 2020, Regensburg, Germany. pp.118-136, ⟨10.1007/978-3-030-49669-2_7⟩. ⟨hal-03243646⟩
Share
Metrics
Record views
16
