findere: fast and precise approximate membership query
Approximate membership query (AMQ) structures such as Cuckoo filters or Bloom filters are widely used for representing large sets of elements. Their lightweight space usage explains their success, mainly as they are the only way to scale hundreds of billions or trillions of elements. However, they suffer by nature from non-avoidable false-positive calls that bias downstream analyses of methods using these data structures. In this work we propose a simple strategy and its implementation for reducing the false-positive rate of any AMQ data structure indexing \kmers (words of length k). The method we propose, called findere, enables to speed-up the queries by a factor two and to decrease the false-positive rate by two order of magnitudes. This achievement is done on the fly at query time, without modifying the original indexing data-structure, without generating false-negative calls and with no memory overhead. This method yields so-called ``construction false positives'', but the amount of such false positives is negligible when the method is used within classical parameter ranges. This method, as simple as effective, reduces either the false-positive rate or the space required to represent a set given a user-defined false-positive rate.
