HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
Accuracy of Mixed Precision Computation in Large Coupled Biological Systems
Aquilina Al Khoury 1, 2, 3, 4 Samuel Bernard 1, 3, 5, 6 Jonathan Rouzaud-Cornabas 1, 2, 7, 4
4 BEAGLE - Artificial Evolution and Computational Biology
LIRIS - Laboratoire d'InfoRmatique en Image et Systèmes d'information, Inria Grenoble - Rhône-Alpes, LBBE - Laboratoire de Biométrie et Biologie Evolutive - UMR 5558
6 DRACULA - Multi-scale modelling of cell dynamics : application to hematopoiesis
CGPhiMC - Centre de génétique et de physiologie moléculaire et cellulaire, Inria Grenoble - Rhône-Alpes, ICJ - Institut Camille Jordan [Villeurbanne]
Abstract : Thanks to the advancement of knowledge and technologies, we want to simulate larger and larger biological systems. But classical methods must be rethink to be able to cope with such system. At the same time, mainly riding the trends of AI/ML, a novel approach is to use methods mixing different arithmetic precision. Indeed, such method improves arithmetic intensity while saving memory, energy and computational time. However, controlling the errors induced by the mix of different precision remains the major issue. In this paper, we are present a new method allowing the use of mixed precision to solve ordinary differential systems of equations. We evaluate our method against large biological systems. We show that with such systems, we can reduce the arithmetic precision of a part of the biological model will retain the same numerical precision.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-03249828
Contributor : Aquilina Al Khoury Connect in order to contact the contributor
Submitted on : Friday, June 4, 2021 - 12:35:46 PM
Last modification on : Monday, May 16, 2022 - 3:12:02 PM
Long-term archiving on: : Sunday, September 5, 2021 - 7:16:47 PM
File
my_article (3).pdf
Identifiers
  • HAL Id : hal-03249828, version 1
Citation
Aquilina Al Khoury, Samuel Bernard, Jonathan Rouzaud-Cornabas. Accuracy of Mixed Precision Computation in Large Coupled Biological Systems. 2021. ⟨hal-03249828⟩
Share
Metrics
Record views
61
Files downloads
107
