EV-GAN: Simulation of extreme events with ReLU neural networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2022
Feedforward neural networks based on Rectified linear units (ReLU) cannot efficiently approximate quantile functions which are not bounded, especially in the case of heavy-tailed distributions. We thus propose a new parametrization for the generator of a Generative adversarial network (GAN) adapted to this framework, basing on extreme-value theory. An analysis of the uniform error between the extreme quantile and its GAN approximation is provided: We establish that the rate of convergence of the error is mainly driven by the second-order parameter of the data distribution. The above results are illustrated on simulated data and real financial data. It appears that our approach outperforms the classical GAN in a wide range of situations including high-dimensional and dependent data.
EV_GAN-HAL-v3.pdf (2.12 Mo) Télécharger le fichier
hal-03250663 , version 1 (04-06-2021)
hal-03250663 , version 2 (16-06-2021)
hal-03250663 , version 3 (22-03-2022)
  • HAL Id : hal-03250663 , version 3
Michaël Allouche, Stéphane Girard, Emmanuel Gobet. EV-GAN: Simulation of extreme events with ReLU neural networks. Journal of Machine Learning Research, 2022, 23 (150), pp.1--39. ⟨hal-03250663v3⟩
1032 Consultations
574 Téléchargements
