Mathematical analysis of a coupling method for the practical computation of homogenized coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2022
We present the mathematical study of a computational approach originally introduced by R. Cottereau in [R. Cottereau, IJNME 2013]. The approach aims at evaluating the effective (a.k.a. homogenized) coefficient of a medium with some fine-scale structure. It combines, using the Arlequin coupling method, the original fine-scale description of the medium with an effective description and optimizes upon the coefficient of the effective medium to best fit the response of an equivalent purely homogeneous medium. We prove here that the approach is mathematically well-posed and that it provides, under suitable assumptions, the actual value of the homogenized coefficient of the original medium in the limit of asymptotically infinitely fine structures. The theory presented here therefore usefully complements our numerical developments of [O. Gorynina, C. Le Bris and F. Legoll, SIAM J. Sci. Computing 2021].
hal-03256156 , version 1 (10-06-2021)
Olga Gorynina, Claude Le Bris, Frederic Legoll. Mathematical analysis of a coupling method for the practical computation of homogenized coefficients. ESAIM: Control, Optimisation and Calculus of Variations, 2022, 28, pp.44. ⟨10.1051/cocv/2022035⟩. ⟨hal-03256156⟩
74 Consultations
0 Téléchargements
