Impact of Preprocessing and Harmonization Methods on the Removal of Scanner Effects in Brain MRI Radiomic Features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cancers Année : 2021
In brain MRI radiomics studies, the non-biological variations introduced by different image acquisition settings, namely scanner effects, affect the reliability and reproducibility of the radiomics results. This paper assesses how the preprocessing methods (including N4 bias field correction and image resampling) and the harmonization methods (either the six intensity normalization methods working on brain MRI images or the ComBat method working on radiomic features) help to remove the scanner effects and improve the radiomic feature reproducibility in brain MRI radiomics. The analyses were based on in vitro datasets (homogeneous and heterogeneous phantom data) and in vivo datasets (brain MRI images collected from healthy volunteers and clinical patients with brain tumors). The results show that the ComBat method is essential and vital to remove scanner effects in brain MRI radiomic studies. Moreover, the intensity normalization methods, while not able to remove scanner effects at the radiomic feature level, still yield more comparable MRI images and improve the robustness of the harmonized features to the choice among ComBat implementations.
cancers-13-03000.pdf (3.47 Mo) Télécharger le fichier
hal-03261617 , version 1 (15-06-2021)
Yingping Li, Samy Ammari, Corinne Balleyguier, Nathalie Lassau, Emilie Chouzenoux. Impact of Preprocessing and Harmonization Methods on the Removal of Scanner Effects in Brain MRI Radiomic Features. Cancers, 2021, 13, ⟨10.3390/cancers13123000⟩. ⟨hal-03261617⟩
72 Consultations
174 Téléchargements
