Automatic extraction of the mitral valve chordae geometry for biomechanical simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Assisted Radiology and Surgery Année : 2021
Mitral valve computational models are widely studied in the literature. They can be used for preoperative planning or anatomical understanding. Manual extraction of the valve geometry on medical images is tedious and requires special training while automatic segmentation is still an open problem. We propose here a fully-automatic pipeline to extract the valve chordae architecture compatible with a computational model. First, an initial segmentation is obtained by sub-mesh topology analysis and RANSAC-like model-fitting procedure. Then the chordal structure is optimized with respect to objective functions based on mechanical, anatomical, and image-based considerations. The approach has been validated on 5 micro CT scans with a graph-based metric and has shown an 87.5% accuracy rate. The method has also been tested within a structural simulation of the mitral valve closed state. Conclusion: Our results show that the chordae architecture resulting from our algorithm can give results similar to experienced users while providing an equivalent biomechanical simulation.
Automatic _extraction_of_the_mitral_valve_chordae_geometry_for_biomechanical _simulation.pdf (3.03 Mo) Télécharger le fichier
Format : Figure, Image
hal-03262496 , version 1 (16-06-2021)
Daryna Panicheva, Pierre-Frédéric Villard, Peter E Hammer, Douglas Perrin, Marie-Odile Berger. Automatic extraction of the mitral valve chordae geometry for biomechanical simulation. International Journal of Computer Assisted Radiology and Surgery, 2021, Proceedings of IPCAI 2021, 16 (5), pp.709-720. ⟨10.1007/s11548-021-02368-3⟩. ⟨hal-03262496⟩
89 Consultations
138 Téléchargements
