Modeling and training strategies for language recognition systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Automatic speech recognition is complementary to language recognition. The language recognition systems exploit this complementarity by using frame-level bottleneck features extracted from neural networks trained with a phone recognition task. Recent methods apply frame-level bottleneck features extracted from an end-to-end sequence-to-sequence speech recognition model. In this work, we study an integrated approach of the training of the speech recognition feature extractor and language recognition modules. We show that for both classical phone recognition and end-to-end sequence-to-sequence features, sequential training of the two modules is not the optimal strategy. The feature extractor can be improved by supervision with the language identification loss, either in a fine-tuning step or in a multi-task training framework. Besides, we notice that end-to-end sequence-to-sequence bottleneck features are on par with classical phone recognition bottleneck features without requiring a forced alignment of the signal with target tokens. However, for sequence-to-sequence, the architecture of the model seems to play an important role; the Conformer architectures leads to much better results than the conventional stacked DNNs approach; and can even be trained directly with the LID module in an end-to-end approach.
bnf-lid_interspeech2021_publication.pdf (169.36 Ko) Télécharger le fichier
hal-03264085 , version 1 (17-06-2021)
Raphaël Duroselle, Md Sahidullah, Denis Jouvet, Irina Illina. Modeling and training strategies for language recognition systems. INTERSPEECH 2021, Aug 2021, Brno, Czech Republic. ⟨10.21437/Interspeech.2021-277⟩. ⟨hal-03264085⟩
175 Consultations
460 Téléchargements
