MLP4NIDS: An Efficient MLP-Based Network Intrusion Detection for CICIDS2017 Dataset - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Arnaud Rosay
More and more embedded devices are connected to the internet and therefore are potential victims of intrusion. While machine learning algorithms have proven to be robust techniques, it is mainly achieved with traditional processing, neural network giving worse results. In this paper, we propose usage of a multi-layer perceptron neural network for intrusion detection and provide a detailed description of our methodology. We detail all steps to achieve better performances than traditional machine learning techniques with a detection of intrusion accuracy above 99% and a low false positive rate kept below 0.7%. Results of previous works are analyzed and compared with the performances of the proposed solution.
487577_1_En_16_Chapter.pdf (441.93 Ko) Télécharger le fichier
hal-03266466 , version 1 (21-06-2021)
Paternité
Arnaud Rosay, Florent Carlier, Pascal Leroux. MLP4NIDS: An Efficient MLP-Based Network Intrusion Detection for CICIDS2017 Dataset. 2nd International Conference on Machine Learning for Networking (MLN), Dec 2019, Paris, France. pp.240-254, ⟨10.1007/978-3-030-45778-5_16⟩. ⟨hal-03266466⟩
238 Consultations
323 Téléchargements
