Point-Based Neural Rendering with Per-View Optimization
There has recently been great interest in neural rendering methods. Some approaches use 3D geometry reconstructed with Multi-View Stereo (MVS) but cannot recover from the errors of this process, while others directly learn a volumetric neural representation, but suffer from expensive training and inference. We introduce a general approach that is initialized with MVS, but allows further optimization of scene properties in the space of input views, including depth and reprojected features, resulting in improved novel view synthesis. A key element of our approach is a differentiable point-based splatting pipeline, based on our bi-directional Elliptical Weighted Average solution. To further improve quality and efficiency of our point-based method, we introduce a probabilistic depth test and efficient camera selection. We use these elements together in our neural renderer, allowing us to achieve a good compromise between quality and speed. Our pipeline can be applied to multi-view harmonization and stylization in addition to novel view synthesis.
KopanasPointBasedNeuralRenderingPerViewOptimization_AuthorVersion.pdf (12.01 Mo)
Télécharger le fichier
