EPR imaging of sinapyl alcohol and its application to the study of plant cell wall lignification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chemical Communications Année : 2021
In bioimaging, bioorthogonal chemistry is most often used to visualize chemical reporters by fluorescence in their native environment. Herein, we show that TEMPO-based probes can be ligated to monolignol reporters by Diels–Alder chemistry in plant cell walls, paving the way for the study of lignification by EPR spectroscopy and imaging.
Simon et al. - 2021 - EPR imaging of sinapyl alcohol and its application to the study of plant cell wall lignification.pdf (1.84 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03269713 , version 1 (24-06-2021)
hal-03269713 , version 2 (18-10-2021)
Paternité - Pas d'utilisation commerciale
Clémence Simon, Cedric Lion, Hania Ahouari, Hervé Vezin, Simon Hawkins, et al.. EPR imaging of sinapyl alcohol and its application to the study of plant cell wall lignification. Chemical Communications, 2021, 57 (3), pp.387-390. ⟨10.1039/d0cc05218c⟩. ⟨hal-03269713v1⟩
56 Consultations
75 Téléchargements
