Switched Observer Design For a Class of Locally Unobservable Time-Varying Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2021
Dmitry Sokolov
Jian Wang
  • Fonction : Auteur
  • PersonId : 1103625
Igor Ryadchikov
  • Fonction : Auteur
  • PersonId : 1103626
Alexey Bobtsov
  • Fonction : Auteur
  • PersonId : 1103627
We consider the problem of state estimation for a parameter-varying system that is unobservable for some values of timevarying parameters. The set of parameter values is divided into a finite number of subsets for which the system is observable, and a switched observer is proposed. A dwell-time condition is defined that ensures exponential convergence. The conditions of stability are formulated in the form of matrix inequalities, which can be used for gains tuning. The obtained theoretical results are supported with an illustrative example and experimental studies for a reaction-wheel pendulum testbench.
AUT_SwObs_final.pdf (1.07 Mo) Télécharger le fichier
hal-03273675 , version 1 (29-06-2021)
Stanislav Aranovskiy, Denis Efimov, Dmitry Sokolov, Jian Wang, Igor Ryadchikov, et al.. Switched Observer Design For a Class of Locally Unobservable Time-Varying Systems. Automatica, 2021, 130, pp.109715. ⟨10.1016/j.automatica.2021.109715⟩. ⟨hal-03273675⟩
78 Consultations
91 Téléchargements
