An efficient representation of 3D buildings: application to the evaluation of city models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
City modeling consists in building a semantic generalized model of the surface of urban objects. These could be seen as a special case of Boundary representation surfaces. Most modeling methods focus on 3D buildings with Very High Resolution overhead data (images and/or 3D point clouds). The literature abundantly addresses 3D mesh processing but frequently ignores the analysis of such models. This requires an efficient representation of 3D buildings. In particular, for them to be used in supervised learning tasks, such a representation should be scalable and transferable to various environments as only a few reference training instances would be available. In this paper, we propose two solutions that take into account the specificity of 3D urban models. They are based on graph kernels and Scattering Network. They are here evaluated in the challenging framework of quality evaluation of building models. The latter is formulated as a supervised multilabel classification problem, where error labels are predicted at building level. The experiments show for both feature extraction strategy strong and complementary results (F-score > 74 % for most labels). Transferability of the classification is also examined in order to assess the scalability of the evaluation process yielding very encouraging scores (F-score > 86 % for most labels).
isprs-archives-XLIII-B2-2021-329-2021.pdf (1.18 Mo) Télécharger le fichier
hal-03276198 , version 1 (01-07-2021)
Oussama Ennafii, Oussama Ennafii, Arnaud Le Bris, Florent Lafarge, Clément Mallet. An efficient representation of 3D buildings: application to the evaluation of city models. ISPRS 2021 - XXIVth Congress of the International Society for Photogrammetry and Remote Sensing, Jul 2021, Nice / Virtual, France. pp.329 - 336, ⟨10.5194/isprs-archives-xliii-b2-2021-329-2021⟩. ⟨hal-03276198⟩
106 Consultations
107 Téléchargements
