A Unifying Framework for Deciding Synchronizability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Several notions of synchronizability of a message-passing system have been introduced in the literature. Roughly, a system is called synchronizable if every execution can be rescheduled so that it meets certain criteria, e.g., a channel bound. We provide a framework, based on MSO logic and (special) tree-width, that unifies existing definitions, explains their good properties, and allows one to easily derive other, more general definitions and decidability results for synchronizability.
concur2021.pdf (731.47 Ko) Télécharger le fichier
hal-03278370 , version 1 (24-08-2021)
  • HAL Id : hal-03278370 , version 1
Benedikt Bollig, Cinzia Di Giusto, Alain Finkel, Laetitia Laversa, Etienne Lozes, et al.. A Unifying Framework for Deciding Synchronizability. CONCUR 2021 - 32nd International Conference on Concurrency Theory, Aug 2021, Paris, France. pp.1-33. ⟨hal-03278370⟩
229 Consultations
151 Téléchargements
