Fokker–Plank System for Movement of Micro-organism Population in Confined Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Physics Année : 2021
We consider self-propelled particles confined between two parallel plates, moving with a constant velocity while their moving direction changes by rotational diffusion. The probability distribution of such microorganisms in confined environment is singular because particles accumulate at the boundaries. This leads us to distinguish between the probability distribution densities in the bulk and in the boundaries. They satisfy a degenerate Fokker-Planck system and we propose boundary conditions that take into account the switching between free-moving and boundary-contacting particles. Relative entropy property, a priori estimates and the convergence to an unique steady state are established. The steady states of both the PDE and individual based stochastic models are compared numerically.
FPT_Mico_Confined.pdf (1.11 Mo) Télécharger le fichier
hal-03278860 , version 1 (06-07-2021)
Jingyi Fu, Benoit Perthame, Min Tang. Fokker–Plank System for Movement of Micro-organism Population in Confined Environment. Journal of Statistical Physics, 2021, 184 (1), ⟨10.1007/s10955-021-02760-y⟩. ⟨hal-03278860⟩
141 Consultations
118 Téléchargements
