Journal articles
An automatic and simplified approach to muscle path modelling
Abstract : The current paper aims at proposing an automatic method to design and adjust simplified muscle paths of a musculoskeletal model. These muscle paths are composed of straight-lines described by a limited set of fixed active via points and an optimization routine is developed to place these via points on the model in order to fit moment arms and musculotendon lengths input data. The method has been applied to a forearm musculoskeletal model extracted from the literature, using theoretical input data as an example. Results showed that for 75% of the muscle set, the relative root mean square error between literature theoretical data and the results from optimized muscle path was under 29.23% for moment arms and of 1.09% for musculotendon lengths. These results confirm the ability of the method to automatically generate computationally efficient muscle paths for musculoskeletal simulations. Using only via points lowers computational expense compared to paths exhibiting wrapping objects. A proper balance between computational time and anatomical realism should be found to help those models being interpreted by practitioners.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03279707
Contributor : Charles Pontonnier Connect in order to contact the contributor
Submitted on : Thursday, July 8, 2021 - 10:57:53 PM
Last modification on : Friday, April 8, 2022 - 4:08:03 PM
Long-term archiving on: : Saturday, October 9, 2021 - 6:08:11 PM
Identifiers
Citation
Claire Livet, Théo Rouvier, Georges Dumont, Charles Pontonnier. An automatic and simplified approach to muscle path modelling. Journal of Biomechanical Engineering, American Society of Mechanical Engineers, 2021, 144 (1), pp.1-9. ⟨10.1115/1.4051870⟩. ⟨hal-03279707⟩
Share
Metrics
Record views
43
Files downloads
207
