Towards a Framework for Open Data Publishers: A Comparison Study Between Sweden and Belgium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Public organizations in the role of publishers publish data for anyone to reuse, which can lead to benefits. However, the process descriptions for this publishing work focus on one or a few issues, which leaves out important areas and decisions. Little seems to be known about variations between publishers based on one common point of comparison. Therefore, this paper presents a comparison between two publishers: Namur (Belgium) and Linköping (Sweden). The comparison is based on a process framework, seven in-depth interviews, document studies, and a verification meeting with one respondent. We learned that the OGD manager is an agent of change who need to balance implementation and guidance, the orthodox method of e-mail registration can be used to engage users and monitor impact, the organizational unit for OGD is cross-organizational, and the publisher process framework could be used as ex-ante strategic guidelines and context-specific recommendations.
499995_1_En_20_Chapter.pdf (203.5 Ko) Télécharger le fichier
hal-03282788 , version 1 (09-07-2021)
Paternité
Jonathan Crusoe, Anthony Simonofski, Antoine Clarinval. Towards a Framework for Open Data Publishers: A Comparison Study Between Sweden and Belgium. 19th International Conference on Electronic Government (EGOV), Aug 2020, Linköping, Sweden. pp.262-274, ⟨10.1007/978-3-030-57599-1_20⟩. ⟨hal-03282788⟩
39 Consultations
27 Téléchargements
