Routine Bandits: Minimizing Regret on Recurring Problems
We study a variant of the multi-armed bandit problem in which a learner faces every day one of B many bandit instances, and call it a routine bandit. More specifically, at each period h ∈ [1, H] , the same bandit b^h is considered during T > 1 consecutive time steps, but the identity b^h is unknown to the learner. We assume all rewards distribution are Gaussian standard. Such a situation typically occurs in recommender systems when a learner may repeatedly serve the same user whose identity is unknown due to privacy issues. By combining banditidentification tests with a KLUCB type strategy, we introduce the KLUCB for Routine Bandits (KLUCB-RB) algorithm. While independently running KLUCB algorithm at each period leads to a cumulative expected regret of Ω(H log T) after H many periods when T → ∞, KLUCB-RB benefits from previous periods by aggregating observations from similar identified bandits, which yields a non-trivial scaling of Ω(log T). This is achieved without knowing which bandit instance is being faced by KLUCB-RB on this period, nor knowing a priori the number of possible bandit instances. We provide numerical illustration that confirm the benefit of KLUCB-RB while using less information about the problem compared with existing strategies for similar problems.
ECML2021_RoutineBandits (Camera-Ready).pdf (1.23 Mo)
Télécharger le fichier
figurestwo_armsT_tunefalse_positive_ratesrates_500.pdf (90.16 Ko)
figurestwo_armsT_tunefalse_positive_ratesrates_5000.pdf (225.67 Ko)
main (2).pdf (84.93 Ko)
main.synctex (1).gz (8.7 Ko)
