Abstract : Employing convolutional neural network models for large scale datasets represents a big challenge. Especially embedded devices with limited resources cannot run most state-of-the-art model architectures in real-time, necessary for many applications. This paper proves the applicability of shunt connections on large scale datasets and narrows this computational gap. Shunt connections is a proposed method for MobileNet compression. We are the first to provide results of shunt connections for the MobileNetV3 model and for segmentation tasks on the Cityscapes dataset, using the DeeplabV3 architecture, on which we achieve compression by 28%, while observing a 3.52 drop in mIoU. The training of shunt-inserted models are optimized through knowledge distillation. The full code used for this work will be available online.
https://hal.inria.fr/hal-03287657 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, July 15, 2021 - 6:09:38 PM Last modification on : Wednesday, October 13, 2021 - 7:58:04 PM Long-term archiving on: : Saturday, October 16, 2021 - 7:02:23 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2024-01-01
Bernhard Haas, Alexander Wendt, Axel Jantsch, Matthias Wess. Neural Network Compression Through Shunt Connections and Knowledge Distillation for Semantic Segmentation Problems. 17th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Jun 2021, Hersonissos, Crete, Greece. pp.349-361, ⟨10.1007/978-3-030-79150-6_28⟩. ⟨hal-03287657⟩
