Conference papers
An Autoencoder Convolutional Neural Network Framework for Sarcopenia Detection Based on Multi-frame Ultrasound Image Slices
Abstract : Multi-Frame classification applications are constituted by instances composed by a package of image frames, such as videos, which frequently require very high computational re-sources. Furthermore, when the input instances contain a large proportion of noise, then the incorporation of noise filtering pre-processing techniques are considered essential. In this work, we propose an AutoEncoder Convolutional Neural Network model for Multi-Frame input applications. The AutoEncoder model aims to reduce the huge dimensional size of the initial instances, compress useful information while simultaneously remove the noise from each frame. Finally, a Convolutional Neural Network classification model is applied on the new transformed and compressed data instances. As a case study scenario for the proposed framework, we utilize Ultrasound images (image slices/frames extracted from every patient via a portable ultrasound device) for Sarcopenia detection. Based on our experimental re-sults the proposed framework outperforms traditional approaches.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03287711
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, July 15, 2021 - 6:12:30 PM
Last modification on : Friday, August 13, 2021 - 4:29:53 PM
Long-term archiving on: : Saturday, October 16, 2021 - 7:11:11 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2024-01-01
Please log in to resquest access to the document
Identifiers
Citation
Emmanuel Pintelas, Ioannis E. Livieris, Nikolaos Barotsis, George Panayiotakis, Panagiotis Pintelas. An Autoencoder Convolutional Neural Network Framework for Sarcopenia Detection Based on Multi-frame Ultrasound Image Slices. 17th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Jun 2021, Hersonissos, Crete, Greece. pp.209-219, ⟨10.1007/978-3-030-79150-6_17⟩. ⟨hal-03287711⟩
Share
Metrics
Record views
40
