Low-order Prandtl-Glauert-Lorentz based Absorbing Boundary Conditions for solving the convected Helmholtz equation with Discontinuous Galerkin methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2022
We construct Absorbing Boundary Conditions (ABCs) for the convected Helmholtz equation that are easy to implement in a Hybridizable Discontinuous Galerkin (HDG) formulation. The construction is based upon the Prandtl-Glauert-Lorentz map which transforms the convected Helmholtz equation into the regular Helmholtz equation. The new ABCs are thus issued from classical Bayliss-Gunztburger-Turkel ABCs and are valid for carrier flows that vary inside the computational domain but become uniform far away from the source. They lead to accurate numerical results for low and intermediate Mach numbers using a HDG formulation with the acoustic potential and the total flux as unknowns.
paper_lorentz_v2.pdf (4.34 Mo) Télécharger le fichier
hal-03288930 , version 1 (16-07-2021)
hal-03288930 , version 2 (23-06-2022)
Hélène Barucq, Nathan Rouxelin, Sébastien Tordeux. Low-order Prandtl-Glauert-Lorentz based Absorbing Boundary Conditions for solving the convected Helmholtz equation with Discontinuous Galerkin methods. Journal of Computational Physics, 2022, 468, ⟨10.1016/j.jcp.2022.111450⟩. ⟨hal-03288930v2⟩
215 Consultations
219 Téléchargements
