A Measure Theoretical Approach to the Mean-field Maximum Principle for Training NeurODEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2023
In this paper we consider a measure-theoretical formulation of the training of NeurODEs in the form of a mean-field optimal control with $L^2$-regularization of the control. We derive first order optimality conditions for the NeurODE training problem in the form of a mean-field maximum principle, and show that it admits a unique control solution, which is Lipschitz continuous in time. As a consequence of this uniqueness property, the mean-field maximum principle also provides a strong quantitative generalization error for finite sample approximations, yielding a rigorous justification of a phenomenon that we call \textit{coupled descent}, indicating the simultaneous decrease of generalization and training errors. We consider two approaches to the derivation of the mean-field maximum principle, including one that is based on a generalized Lagrange multiplier theorem on convex sets of spaces of measures, which is arguably much simpler than those currently available in the literature for mean-field optimal control problems. The latter is also new, and can be considered as a result of independent interest.
Mean field control.pdf (6.43 Mo) Télécharger le fichier
hal-03289521 , version 1 (17-07-2021)
hal-03289521 , version 2 (17-10-2023)
Benoît Bonnet, Cristina Cipriani, Massimo Fornasier, Hui Huang. A Measure Theoretical Approach to the Mean-field Maximum Principle for Training NeurODEs. Nonlinear Analysis: Theory, Methods and Applications, 2023, 227, pp.113161. ⟨10.1016/j.na.2022.113161⟩. ⟨hal-03289521v2⟩
97 Consultations
102 Téléchargements
