Journal articles
Genetic Variants Associated with Non-Alcoholic Fatty Liver Disease Do Not Associate with Measures of Sub-Clinical Atherosclerosis: Results from the IMPROVE Study
Abstract : Non-alcoholic fatty liver disease (NAFLD) and atherosclerosis-related cardiovascular diseases (CVD) share common metabolic pathways. We explored the association between three NAFLD-associated single nucleotide polymorphisms (SNPs) rs738409, rs10401969, and rs1260326 with sub-clinical atherosclerosis estimated by the carotid intima-media thickness (c-IMT) and the inter-adventitia common carotid artery diameter (ICCAD) in patients free from clinically overt NAFLD and CVD. The study population is the IMPROVE, a multicenter European study (n = 3711). C-IMT measures and ICCAD were recorded using a standardized protocol. Linear regression with an additive genetic model was used to test for association of the three SNPs with c-IMT and ICCAD. In secondary analyses, the association of the three SNPs with c-IMT and ICCAD was tested after stratification by alanine aminotransferase levels (ALT). No associations were found between rs738409, rs1260326, rs10401969, and c-IMT or ICCAD. Rs738409-G and rs10401969-C were associated with ALT levels (p < 0.001). In patients with ALT levels above 28 U/L (highest quartile), we observed an association between rs10401969-C and c-IMT measures of c-IMTmax and c-IMTmean-max (p = 0.018 and 0.021, respectively). In conclusion, NAFLD-associated SNPs do not associate with sub-clinical atherosclerosis measures. However, our results suggest a possible mediating function of impaired liver function on atherosclerosis development.
Complete list of metadata
https://hal.sorbonne-universite.fr/hal-03298638
Contributor : Gestionnaire Hal-Su <>
Submitted on : Friday, July 23, 2021 - 5:14:51 PM
Last modification on : Sunday, July 25, 2021 - 3:35:47 AM
File
genes-11-01243-v2.pdf
Publication funded by an institution
Identifiers
Collections
Citation
Luigi Castaldo, Federica Laguzzi, Rona Strawbridge, Damiano Baldassarre, Fabrizio Veglia, et al.. Genetic Variants Associated with Non-Alcoholic Fatty Liver Disease Do Not Associate with Measures of Sub-Clinical Atherosclerosis: Results from the IMPROVE Study. Genes, MDPI, 2020, 11 (11), pp.1243. ⟨10.3390/genes11111243⟩. ⟨hal-03298638⟩
Share
Metrics
Record views
55
Files downloads
16
