Data Analysis for Electrolyte Systems : A Method Illustrated on Alkali Halides in Water - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Chemical and Engineering Data Année : 2021
In the recent years, the need to improve the thermodynamic models, particularly making them more precise and predictable for complex systems, has increased 1,2. The complexity of electrolyte systems is due to the strong interactions between ions, the hydration forces that take place during salt dissociation, and the physical forces at high concentrations of solute. Consequently, the existing thermodynamic electrolyte models show some limitations and are far from being completely optimized for industrial simulations. Thermodynamics based on electrolyte mixtures and mixed solvents requires further development and research 3. The EleTher Joint Industrial Project (JIP) aims at promoting research in this field. A practical workflow is under development where the first stage consists in analyzing the data.
Chimie
Dataanalysis_accepted.pdf (2.04 Mo) Télécharger le fichier
DataAnalysis_SI.pdf (98.57 Ko) Télécharger le fichier
DataAnalysis_SI2.pdf (7.62 Mo) Télécharger le fichier
hal-03298689 , version 1 (23-07-2021)
Santiago Vaque Aura, Juan-Sebastian Roa Pinto, Nicolas Ferrando, Jean-Charles de Hemptinne, Antoon ten Kate, et al.. Data Analysis for Electrolyte Systems : A Method Illustrated on Alkali Halides in Water. Journal of Chemical and Engineering Data, In press, 66 (8), pp.2976-2990. ⟨10.1021/acs.jced.1c00105⟩. ⟨hal-03298689⟩
Collections
IFP
123 Consultations
149 Téléchargements
