New Features of P3$\delta$ software: Partial Pole Placement via Delay Action - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents the software Partial Pole Placement via Delay Action, or P3$\delta$ for short. P3$\delta$ is a Python software with a friendly user interface for the design of parametric stabilizing feedback laws with time-delays, thanks to two properties of the distribution of quasipolynomials' zeros, called multiplicity-induced-dominancy and coexisting real roots-induced-dominancy. After recalling recent theoretical results on these properties and their use for the feedback stabilization of control systems operating under time delays, the paper presents the main features of the current version of P3$\delta$. We detail, in particular, the assignable admissible region (the set of allowable dominant roots and the corresponding delay), which helps the user in the choice of input information, allowing a reliable stabilizing delayed feedback. We also present the newly set online version of P3$\delta$.
2021-TDS-p3delta.pdf (564.92 Ko) Télécharger le fichier
hal-03298710 , version 1 (23-07-2021)
hal-03298710 , version 2 (17-08-2021)
Islam Boussaada, Guilherme Mazanti, Silviu-Iulian Niculescu, Adrien Leclerc, Jayvir Raj, et al.. New Features of P3$\delta$ software: Partial Pole Placement via Delay Action. TDS 2021 - 16th IFAC Workshop on Time Delay Systems, Sep 2021, Guangzhou, China. pp.215-221, ⟨10.1016/j.ifacol.2021.11.142⟩. ⟨hal-03298710v2⟩
224 Consultations
137 Téléchargements
