Formal Verification of a Concurrent Bounded Queue in a Weak Memory Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We use Cosmo, a modern concurrent separation logic, to formally specify and verify an implementation of a multiple-producer multiple-consumer concurrent queue in the setting of the Multicore OCaml weak memory model. We view this result as a demonstration and experimental verification of the manner in which Cosmo allows modular and formal reasoning about advanced concurrent data structures. In particular, we show how the joint use of logically atomic triples and of Cosmo's views makes it possible to describe precisely in the specification the interaction between the queue library and the weak memory model.
main.pdf (611.37 Ko) Télécharger le fichier
hal-03298759 , version 1 (24-07-2021)
Glen Mével, Jacques-Henri Jourdan. Formal Verification of a Concurrent Bounded Queue in a Weak Memory Model. ICFP 2021 - 26th ACM SIGPLAN International Conference on Functional Programming, Aug 2021, Virtual, Japan. ⟨10.1145/3473571⟩. ⟨hal-03298759⟩
134 Consultations
71 Téléchargements
