A multiscale analysis of early flower development in Arabidopsis provides an integrated view of molecular regulation and growth control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Developmental Cell Année : 2021
Emmanuel Faure
Feng Zhao
Pradeep Das
  • Fonction : Auteur
  • PersonId : 1204352
Grégoire Malandain
We have analyzed the link between the gene regulation and growth during the early stages of flower development in Arabidopsis. Starting from time-lapse images, we generated a 4D atlas of early flower development, including cell lineage, cellular growth rates, and the expression patterns of regulatory genes. This information was introduced in MorphoNet, a web-based platform. Using computational models, we found that the literature-based molecular network only explained a minority of the gene expression patterns. This was substantially improved by adding regulatory hypotheses for individual genes. Correlating growth with the combinatorial expression of multiple regulators led to a set of hypotheses for the action of individual genes in morphogenesis. This identified the central factor LEAFY as a potential regulator of heterogeneous growth, which was supported by quantifying growth patterns in a leafy mutant. By providing an integrated view, this atlas should represent a fundamental step toward mechanistic models of flower development.
2020.09.25.313312v1.full.pdf (8.15 Mo) Télécharger le fichier
hal-03299500 , version 1 (27-07-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Yassin Refahi, Argyris Zardilis, Gaël Michelin, Raymond Wightman, Bruno Leggio, et al.. A multiscale analysis of early flower development in Arabidopsis provides an integrated view of molecular regulation and growth control. Developmental Cell, 2021, 56 (4), pp.540-556.e8. ⟨10.1016/j.devcel.2021.01.019⟩. ⟨hal-03299500⟩
202 Consultations
139 Téléchargements
