Asymptotic analysis of abstract two-scale wave propagation problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
This work addresses the mathematical analysis, by means of asymptotic analysis, of linear wave propagation problems involving two scales, represented by a single small parameter, and written in an abstract setting. This abstract setting is defined using linear operators in Hilbert spaces and also enters the framework of semi-group theory. In this setting, we show, under some assumptions on the structure of the wave propagation problems, weak and strong convergence of solutions with respect to the small parameter towards the solution of a well-defined limit problem.
twoscalepb.pdf (414.98 Ko) Télécharger le fichier
hal-03306856 , version 1 (29-07-2021)
  • HAL Id : hal-03306856 , version 1
Sébastien Imperiale. Asymptotic analysis of abstract two-scale wave propagation problems. 2021. ⟨hal-03306856⟩
111 Consultations
92 Téléchargements
