Journal articles
Insertion of hydrophobic spacers on dodecalysines as potential transfection enhancers
Abstract : The use of cationic polymers in gene therapy aims at improving the circulation, protection and delivery of nucleic acids. The modification of poly(L-lysine) (PLL), including the insertion of hydrophobic moieties, is an efficient strategy to enhance the transfection efficiency of this synthetic delivery system. PLL is usually modified through either the extremities of the polymer chains or the amino groups present on the side chains. Herein the synthesis of dodecalysines as model of PLL with hexyl spacing units regularly distributed along the oligomer backbone is reported. Oligolysines terminated with azidohexyl groups were prepared by solid-phase synthesis and ligated by copper-assisted alkyne-azide cycloaddition using propargylamine. The iterative ligation of α-azidohexyloligolysines was more efficient when performed on resin as compared to the ligation in solution. The plasmid DNA transfection efficiency of the hydrophobically modified dodecalysines was then compared to that of unmodified dodecalysine. The results show that when formulated with the helper lipid 1,2-dioleoyl-sn-glycero-3-phosphoethanolamine (DOPE) the hydrophobized dodecalysines exhibited a higher efficiency than the unmodified one. Interestingly, the efficiency could also be increased by the addition of a fusogenic peptide, which paves the way for modifications of the oligolysines that could lead to improved activities.
Document type :
Journal articles
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-03308204
Contributor : Delphine Chan-Seng <>
Submitted on : Thursday, July 29, 2021 - 5:36:26 PM
Last modification on : Friday, July 30, 2021 - 3:42:14 AM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2022-01-19
Please log in to resquest access to the document
Identifiers
Collections
Citation
Clothilde Le Guen, Candice Dussouillez, Antoine Kichler, Delphine Chan-Seng. Insertion of hydrophobic spacers on dodecalysines as potential transfection enhancers. European Polymer Journal, Elsevier, 2021, 157, pp.110654. ⟨10.1016/j.eurpolymj.2021.110654⟩. ⟨hal-03308204⟩
Share
Metrics
Record views
29
