Journal articles
Half‐Sandwich Nickel(II) NHC‐Picolyl Complexes as Catalysts for the Hydrosilylation of Carbonyl Compounds: Evidence for NHC‐Nickel Nanoparticles under Harsh Reaction Conditions
Abstract : The cationic [NiCp(Mes-NHC-CH2py]Br complex 2 a was prepared directly by the reaction of nickelocene with 1-(2-picolyl)-3-mesityl-imidazolium bromide (1), and its PF6− derivative 2 b, by subsequent salt metathesis. X-ray diffraction studies and Variable Temperature 1H NMR experiments run with 2 a and 2 b strongly suggest the bidentate coordination of the picolyl-functionalized carbene to the nickel both in the solid state and in solution in both cases. These data suggest the absence of hemilabile behavior of the latter, even in the presence of a coordinating anion. Both complexes show similar activity in aldehyde hydrosilylation, further implying the absence of hemilability of the picolyl-functionalized carbene, and effectively reduce a broad scope of aldehydes in the absence of additive under mild conditions. In the case of ketones, effective hydrosilylation is only observed in the presence of a catalytic amount of potassium t-butoxide at 100 °C. Dynamic light scattering, scanning transmission electron microscopy and X-ray photoelectron spectroscopy show evidence for the involvement of NHC-picolyl-Ni nanoparticles under these conditions.
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-03308504
Contributor : Christophe Michon <>
Submitted on : Thursday, July 29, 2021 - 6:28:40 PM
Last modification on : Friday, July 30, 2021 - 3:42:14 AM
File
Manuscript HAL_Eur. J. Inorg. ...
Identifiers
Collections
Citation
Franck Ulm, Saurabh Shahane, Lai Truong-Phuoc, Thierry Romero, Vasiliki Papaefthimiou, et al.. Half‐Sandwich Nickel(II) NHC‐Picolyl Complexes as Catalysts for the Hydrosilylation of Carbonyl Compounds: Evidence for NHC‐Nickel Nanoparticles under Harsh Reaction Conditions. European Journal of Inorganic Chemistry, Wiley-VCH Verlag, In press, ⟨10.1002/ejic.202100371⟩. ⟨hal-03308504⟩
Share
Metrics
Record views
42
Files downloads
24
