Journal articles
Macroscopic Model for Passive Mass Dispersion in Porous Media Including Knudsen and Diffusive Slip Effects
Abstract : In this work, a macroscopic model for incompressible and Newtonian gas flow coupled to Fickian and advective transport of a passive solute in rigid and homogeneous porous media is derived. At the pore-scale, both momentum and mass transport phenomena are coupled, not only by the convective mechanism in the mass transport equation, but also in the solid-fluid interfacial boundary condition. This boundary condition is a generalization of the Kramers-Kistemaker slip condition that includes the Knudsen effects. The resulting upscaled model, applicable in the bulk of the porous medium, corresponds to: 1) A Darcy-type model that involves an apparent permeability tensor, complemented by a dispersive term and 2) A macroscopic convection-dispersion equation for the solute, in which both the macroscopic velocity and the total dispersion tensor are influenced by the slip effects taking place at the pore-scale. The use of the model is restricted by the starting assumptions imposed in the governing equations at the pore scale and by the (spatial and temporal) constraints involved in the upscaling process. The different regimes of application of the model, in terms of the Péclet number values, are discussed as well as its extents and limitations. This new model generalizes previous attempts that only include either Knudsen or diffusive slip effects in porous media.
Document type :
Journal articles
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-03309031
Contributor : Didier Lasseux <>
Submitted on : Friday, July 30, 2021 - 7:46:13 AM
Last modification on : Saturday, July 31, 2021 - 3:33:36 AM
File
Front_Water.pdf
Publisher files allowed on an open archive
Identifiers
Citation
Francisco Valdés-Parada, Didier Lasseux. Macroscopic Model for Passive Mass Dispersion in Porous Media Including Knudsen and Diffusive Slip Effects. Frontiers in Water, Frontiers, 2021, 3, pp.666279. ⟨10.3389/frwa.2021.666279⟩. ⟨hal-03309031⟩
Share
Metrics
Record views
46
Files downloads
34
