Accessibility Properties of Abnormal Geodesics in Optimal Control Illustrated by Two Case Studies. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Control and Related Fields Année : 2023
In this article, we use two case studies from geometry and optimal control of chemical network to analyze the relation between abnormal geodesics in time optimal control, accessibility properties and regularity of the time minimal value function.
zermelo_2022.pdf (1.95 Mo) Télécharger le fichier
hal-03310348 , version 1 (30-07-2021)
hal-03310348 , version 2 (23-02-2022)
hal-03310348 , version 3 (29-04-2022)
hal-03310348 , version 4 (22-03-2023)
hal-03310348 , version 5 (03-10-2023)
Bernard Bonnard, Jérémy Rouot, Boris Wembe. Accessibility Properties of Abnormal Geodesics in Optimal Control Illustrated by Two Case Studies.. Mathematical Control and Related Fields, 2023, 13 (4), pp.1618-1638. ⟨10.3934/mcrf.2022052⟩. ⟨hal-03310348v5⟩
464 Consultations
281 Téléchargements
