A simple equilibration procedure leading to polynomial-degree-robust a posteriori error estimators for the curl-curl problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We introduce two a posteriori error estimators for Nédélec finite element discretizations of the curl-curl problem. These estimators pertain to a new Prager-Synge identity and an associated equilibration procedure. They are reliable and efficient, and the error estimates are polynomial-degree-robust. In addition, when the domain is convex, the reliability constants are fully computable. The proposed error estimators are also cheap and easy to implement, as they are computed by solving divergence-constrained minimization problems over edge patches. Numerical examples highlight our key findings, and show that both estimators are suited to drive adaptive refinement algorithms. Besides, these examples seem to indicate that guaranteed upper bounds can be achieved even in non-convex domains.
chaumontfrelet_2021a.pdf (523.85 Ko) Télécharger le fichier
hal-03323859 , version 1 (23-08-2021)
Théophile Chaumont-Frelet. A simple equilibration procedure leading to polynomial-degree-robust a posteriori error estimators for the curl-curl problem. 2021. ⟨hal-03323859⟩
45 Consultations
50 Téléchargements
