Lucas-Kanade Reloaded: End-to-End Super-Resolution from Raw Image Bursts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This presentation addresses the problem of reconstructing a high-resolution image from multiple lower-resolution snapshots captured from slightly different viewpoints in space and time. Key challenges for solving this super-resolution problem include (i) aligning the input pictures with sub-pixel accuracy, (ii) handling raw (noisy) images for maximal faithfulness to native camera data, and (iii) designing/learning an image prior (regularizer) well suited to the task. We address these three challenges with a hybrid algorithm building on the insight from Wronski et al. that aliasing is an ally in this setting, with parameters that can be learned end to end, while retaining the interpretability of classical approaches to inverse problems. The effectiveness of our approach is demonstrated on synthetic and real image bursts, setting a new state of the art on several benchmarks and delivering excellent qualitative results on real raw bursts captured by smartphones and prosumer cameras.
main.pdf (23.64 Mo) Télécharger le fichier
hal-03323885 , version 1 (23-08-2021)
  • HAL Id : hal-03323885 , version 1
Bruno Lecouat, Jean Ponce, Julien Mairal. Lucas-Kanade Reloaded: End-to-End Super-Resolution from Raw Image Bursts. ICCV 2021 - International Conference on Computer Vision, Oct 2021, Virtual, France. pp.1-16. ⟨hal-03323885⟩
631 Consultations
325 Téléchargements
