The Mays and Musts of Concurrent Strategies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Concurrent strategies based on event structures are examined from the viewpoint of 'may' and 'must' testing in traditional process calculi. In their pure form concurrent strategies fail to expose the deadlocks and divergences that can arise in their composition. This motivates an extension of the bicategory of concurrent strategies to treat the 'may' and 'must' behaviour of strategies under testing. One extension adjoins neutral moves to strategies but in so doing loses identities w.r.t. composition. This in turn motivates another extension in which concurrent strategies are accompanied by stopping configurations; the ensuing stopping strategies inherit the structure of a bicategory from that of strategies. The technical developments converge in providing characterisations of the 'may' and 'must' equivalences and preorders on strategies.
MayMust-revised.pdf (297.08 Ko) Télécharger le fichier
hal-03323995 , version 1 (23-08-2021)
Simon Castellan, Pierre Clairambault, Glynn Winskel. The Mays and Musts of Concurrent Strategies. 2021. ⟨hal-03323995⟩
67 Consultations
56 Téléchargements
