The Multiverse: Logical Modularity for Proof Assistants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Proof assistants play a dual role as programming languages and logical systems. As programming languages, proof assistants offer standard modularity mechanisms such as first-class functions, type polymorphism and modules. As logical systems, however, modularity is lacking, and understandably so: incompatible reasoning principles-such as univalence and uniqueness of identity proofs-can indirectly lead to logical inconsistency when used in a given development, even when they appear to be confined to different modules. The lack of logical modularity in proof assistants also hinders the adoption of richer programming constructs, such as effects. We propose the multiverse, a general type-theoretic approach to endow proof assistants with logical modularity. The multiverse consists of multiple universe hierarchies that statically describe the reasoning principles and effects available to define a term at a given type. We identify sufficient conditions for this structuring to modularly ensure that incompatible principles do not interfere, and to locally restrict the power of dependent elimination when necessary. This extensible approach generalizes the ad-hoc treatment of the sort of propositions in the Coq proof assistant. We illustrate the power of the multiverse by describing the inclusion of Coq-style propositions, the strict propositions of Gilbert et al., the exceptional type theory of Pédrot and Tabareau, and general axiomatic extensions of the logic.
main.pdf (677.3 Ko) Télécharger le fichier
hal-03324596 , version 1 (23-08-2021)
  • HAL Id : hal-03324596 , version 1
Kenji Maillard, Nicolas Margulies, Matthieu Sozeau, Nicolas Tabareau, Éric Tanter. The Multiverse: Logical Modularity for Proof Assistants. 2021. ⟨hal-03324596⟩
150 Consultations
162 Téléchargements
