3D Semantic Scene Completion: a Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2021
Semantic Scene Completion (SSC) aims to jointly estimate the complete geometry and semantics of a scene, assuming partial sparse input. In the last years following the multiplication of large-scale 3D datasets, SSC has gained significant momentum in the research community because it holds unresolved challenges. Specifically, SSC lies in the ambiguous completion of large unobserved areas and the weak supervision signal of the ground truth. This led to a substantially increasing number of papers on the matter. This survey aims to identify, compare and analyze the techniques providing a critical analysis of the SSC literature on both methods and datasets. Throughout the paper, we provide an in-depth analysis of the existing works covering all choices made by the authors while highlighting the remaining avenues of research. SSC performance of the SoA on the most popular datasets is also evaluated and analyzed.
2103.07466.pdf (13.47 Mo) Télécharger le fichier
hal-03324932 , version 1 (24-08-2021)
Luis Roldão, Raoul de Charette, Anne Verroust-Blondet. 3D Semantic Scene Completion: a Survey. International Journal of Computer Vision, 2021, ⟨10.1007/s11263-021-01504-5⟩. ⟨hal-03324932⟩
Collections
INRIA INRIA2
65 Consultations
124 Téléchargements
