Leveraging Formal Specifications to Generate Fuzzing Suites - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
When testing a library, developers typically first have to capture the semantics they want to check. They then write the code implementing these tests and find relevant test cases that expose possible misbehaviours. In this work, we present a tool that automatically takes care of these last two steps by automatically generating fuzz testing suites from OCaml interfaces annotated with formal behavioural specifications. We also show some ongoing experiments on the capabilities and limitations of fuzzing applied to real-world libraries.
OCaml_2021.pdf (130.58 Ko) Télécharger le fichier
hal-03328646 , version 1 (30-08-2021)
  • HAL Id : hal-03328646 , version 1
Nicolas Osborne, Clément Pascutto. Leveraging Formal Specifications to Generate Fuzzing Suites. OCaml Users and Developers Workshop, co-located with the 26th ACM SIGPLAN International Conference on Functional Programming, Aug 2021, Virtual, United States. ⟨hal-03328646⟩
156 Consultations
122 Téléchargements
