Generation of a fault-tolerant clock through redundant crystal oscillators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microelectronics Reliability Année : 2021
Having a precise and stable clock that is still fault tolerant is a fundamental prerequisite in safety critical realtime systems. However, combining redundant independent clock sources to form a unified fault-tolerant clock supply is non-trivial, especially when redundant clock outputs are required-e.g., for supplying the replicated nodes within a TMR architecture through a clock network that does not suffer from a single point of failure. Having these outputs fail independent but still keeping them tightly synchronized is highly desirable, as it substantially eases the design of the overall architecture. In this paper we address exactly this challenge. Our approach extends an existing, ring-oscillator like distributed clock generation scheme by augmenting each of its constituent nodes with a stable clock reference. We introduce the appropriately modified algorithm and illustrate its operation by simulation experiments. These experiments further demonstrate that the four clock outputs of our circuit do not share a single point of failure, have small and bounded skew, remain stabilized to one crystal source during normal operation, do not propagate glitches from one failed clock to a correct one, and only exhibit slightly extended clock cycles during a short stabilization period after a component failure. In addition we give a rigorous formal proof for the correctness of the algorithm on an abstraction level that is close to the implementation.
main.pdf (339.53 Ko) Télécharger le fichier
hal-03329844 , version 1 (31-08-2021)
Wolfgang Dür, Matthias Függer, Andreas Steininger. Generation of a fault-tolerant clock through redundant crystal oscillators. Microelectronics Reliability, 2021, 120, pp.114088. ⟨10.1016/j.microrel.2021.114088⟩. ⟨hal-03329844⟩
89 Consultations
73 Téléchargements
