Efficient Spectral Rendering on the GPU for Predictive Rendering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2021
Current graphic processing units (GPU) in conjunction with specialized APIs open the possibility of interactive path tracing. Spectral rendering is necessary for accurate and predictive light transport simulation, especially to render specific phenomena such as light dispersion. However, it requires larger assets than traditional RGB rendering pipelines. Thanks to the increase of available onboard memory on newer graphic cards, it becomes possible to load larger assets onto the GPU, making spectral rendering feasible. In this chapter, we describe the strengths of spectral rendering and present our approach for implementing a spectral path tracer on the GPU. We also propose solutions to limit the impact on memory when handling finely sampled spectra or large scenes.
Efficient Spectral Rendering on the GPU.pdf (8.74 Mo) Télécharger le fichier
hal-03331619 , version 1 (01-09-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
David Murray, Alban Fichet, Romain Pacanowski. Efficient Spectral Rendering on the GPU for Predictive Rendering. Ray Tracing Gems II, Springer, pp.673 - 698, 2021, 978-1-4842-7185-8. ⟨10.1007/978-1-4842-7185-8_42⟩. ⟨hal-03331619⟩
240 Consultations
1078 Téléchargements
