Multiomics Data Integration for Gene Regulatory Network Inference with Exponential Family Embeddings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The advent of omics technologies has enabled the generation of huge, complex, heterogeneous, and high-dimensional omics data. Imposing numerous challenges in data integration, these data could lead to a better understanding of the organism's cellular system. Omics data are typically represented as networks to study relations between biological entities, such as protein-protein interaction, gene regulation, and signal transduction. To this end, network embedding approaches allow us to learn latent feature representations for nodes of a graph structure. In this study, we propose a new methodology to learn embeddings by modeling the underlying interactions among biological entities (nodes) with exponential family distributions from a well-chosen set of omics modalities. We evaluate our proposed method based on the gene regulatory network (GRN) inference problem. As the ground truth for evaluation, we use GRN available in public databases and demonstrate its effectiveness by comparing to other network integration approaches.
Multiomics_GRN_EUSIPCO_2021.pdf (501.17 Ko) Télécharger le fichier
hal-03336884 , version 1 (07-09-2021)
  • HAL Id : hal-03336884 , version 1
Surabhi Jagtap, Abdulkadir Çelikkanat, Aurélie Pirayre, Frederique Bidard, Laurent Duval, et al.. Multiomics Data Integration for Gene Regulatory Network Inference with Exponential Family Embeddings. EUSIPCO - 29th European Signal Processing Conference, Aug 2021, Dublin / Online, Ireland. ⟨hal-03336884⟩
149 Consultations
178 Téléchargements
